1 long beep, 2 very short beep then 1 short beep, only changed dead PSU and disconnected all devices but master HDD and output video cable, keyboard and mouse
SOURCE: Abit beep code error and LED code of 87
Hi had similar problem today, 1 long 4 short beeps - so not exactly the same.
I ended up resetting the CMOS - and this fixed my problem.
Hope that helps!
SOURCE: ERROR 87 ON MOTHERBOARD LED AND 1 LONG BEEP 3
Check whether the RAM has been installed or properly inserted.
SOURCE: abit av8 bios post codes 8.3 - 8.6 - 9.C
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
SOURCE: my abit ix38 get 8.7.
i have been having the same sort of problem with my IX38 quad GT and after hours of trying various things i have decided i need to see if the problem is my processor. let me explain...
i have an abit IX38 that i have been running with an E6550 dual core processor. had it for years now with no problems. i recently got a Q9450 quad core from ebay to upgrade, and ran into problems. basically i can't get the **** thing to boot with the Q9450. when i try to boot with the 8pin ATX processor plug, it goes straight to post code 8.3. and shuts off. if i remove the 8pin ATX it will boot to code 8.7. and run for about 15s and then reboot back to 8.7. post code 8.7. is a check CPU voltage issue. code 8.3. says something about saving back to the CMOS stack and the manual says its a psu issue.
i have tried pretty much everything, from changing the psu, to gpu to RAM and more with the same results. so at this point i wanted to get anyone who might have something to say about the situation to comment on if it might be the processor is bad, and i got burned on something from ebay. i do have one last step, and that would be to rule out the mobo (by having my bro install it in his computer which has a Q9450)
any responses would be greatly appreciated.
