The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
Remove the top and use a blow dryer on warm towards the control board for a couple of minutes. If it works after that you have a moisture problem. Mine did it after every wash. Try dielectric grease.
SOURCE: error code E90
Remove the front panel and on the right side at the bottom youll find the main Circuit board.There is a connector on the harness that needs to be making a tighter contact.Make sure that all the wires that are in contact with the circuit board are firmly touching.Sometimes using a pair if pointed tweezers and a sewing needle will be all you need to fix this .There is hope so dont go out and replace any parts just yet. .
