Gateway M305CRV Notebook Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RAM I installed 1 1GB of ram and 1 512 MB of ram in the 2 slots of my P4 motherboard(1.8GHz)but the system hangs after 10 mins or the graphic driver stops responding.What should i do?i have only 2 slots
Dave Harris
Level 2:
Novelist:
Scholar:
  • Expert 117 Answers
  • Posted on Jan 16, 2009
Dave Harris
Expert
Level 2:
Novelist:
Scholar:
Answers
117
Questions
Helped
40349
Points
192
If the system boots and runs, even if only for 10 minutes, then almost certainly the motherboard supports whatever type of RAM you have plugged into it. As someone said, it may be sub-optimal but it is usable. Even so, I would check (as others have said) that you have used the correct type of RAM for your PC.
My guess is that the extra current being drawn from the internal power supply board is causing components to overheat. If it's like most laptops & more than, say, one year old, then the cooling fans will have sucked a load of dust into the guts of the machine, blocking the passage of cooling air. You will need to get a techie (unless you're confident enough & have the tools to do it yourself) to open the case, remove the CPU fan & heatsink & clean it out & check for blockages anywhere else, especially around the power conditioning circuitry.
Once last thought: all laptops have a small board, or area of the motherboard, which takes the current provided by the external power brick and turns it into the various voltages needed by the rest of the PC. It may be that, although the motherboard can handle that much RAM, the power supply can't and it is overheating for that reason - leading to random lockups.
Anonymous
Level 2:
  • Expert 158 Answers
Anonymous
Expert
Level 2:
Answers
158
Questions
Helped
63766
Points
446
Use synchronous settings for optimal performance. Use either 1GB or 512GB both of same ratings (for ex. PC2100 or PC2700) in both the slots. Usually you get a sluggish performance if RAMs of different capacity are installed
Thanx
Anonymous
Level 2:
Scholar:
  • Expert 170 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
170
Questions
Helped
34056
Points
404
Not all ram is compatiable with your motherboard. Just because you have 2 slots does not mean that you can put 1.5 gigs of ram in there. Your board might only support 2 sticks of  512, or 2 sticks of 256. Google the make and model of the motherboard you have, and it should tell you how much and what kind of ram it supports.  Or tell me what kind of board and model it is and I well tell you what it supports. I hope this helps, let me know how you made out, and please rate my answer.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
