SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
SOURCE: error code E90
Remove the front panel and on the right side at the bottom youll find the main Circuit board.There is a connector on the harness that needs to be making a tighter contact.Make sure that all the wires that are in contact with the circuit board are firmly touching.Sometimes using a pair if pointed tweezers and a sewing needle will be all you need to fix this .There is hope so dont go out and replace any parts just yet. .
SOURCE: I have a Fridgidaire Front
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
SOURCE: cleaning the lint trap of my Affinity washing machine
no lint trap...the best you can do is give it a hot wash bleach with a cold rinse,,,onthejob
