You must remove all covers possible in order to watch the drip source using a flashlight. Once found, yes, the leak is fixable. All leaks are fixable...depends on cost of fix. A main pump seal repair/replace may be too expensive. Again, cost is the main factor. So find the leak, then get a repair estimate, if necessary...or get a screwdriver and tighten the hose clamp.
Yes, thank you...I just haven't had time to comment! We found the leak and tightened it, thanks for responding!
Our whirlpool built-in dishwasher leaks along the bottom of the door, particularly on the left side as you face it. We ordered and replaced the door gasket with a new one, with no improvement. All hose connections check good. Any ideas?
Whirlpool dishwasher Model# DU890SWKQ0 Water appears to be coming from underneath on right side as you face dishwasher leak is small but enough to form a good size puddle any ideas? We have not tired anything yet since we are not sure what to look for.
water leaking from front of frigidaire dishwasher
