Curtis-Mathis CM27101S TV Logo
Posted on Jan 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SCREEN SIZE WHAT IS THE SCREEN SIZE FOR CURTIS MATHIS TV MODEL CM27101S
Jim London
Level 2:
  • Expert 257 Answers
  • Posted on Jan 29, 2009
Jim London
Expert
Level 2:
Answers
257
Questions
0
Helped
276536
Points
840
Hi, As indicated by your model number the screen size is 27 inch, which is a common diagonal measurement. This TV has a standard aspect ratio of 4:3.
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
How big is this tv
measure the screen only
from corner to corner
E.g. top right corner of screen to bottom left corner of screen
I have a curtis mathes model plef398ccd how much would it cost to buy this T.V.
$50 work great but frame cosmatic don't look that great.$75 buck,if still in exellent conditions as tv work and vey good condition cosmatic looking frame.
Tv screen went blank and is in thin horizontal white lne?
cold solder in vertical ic or vertical ic bad. try resolder first.
Nedd to reset TV manually...... remote is not working
I have a curtis Mathis model number cm19102 . I have no remote. It is stuck on no more than 14 channels. Then the word line comes up on blank screen. How can I get it to get more channels
Curtis mathis tv takes to for picture to show after turning on
Look for a bad caps 250volt 2.2MF and a 25 volt 47MF near the horizontal deflection! And you may as well check the caps near the vertical IC as these are going bad...you have board out..you may as well do this. Then you will have a reconditoned TV with added years!
I have a curtis mathes/tronics tv Made in May/2001 Serial no#CM19022S I am trying to hook up a digital conventer box to it and I am having troubles. I also need a users manual for this model and year, pls...
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
Trying to connect a wii to my curtis mathis tv and we can not figure out how to set the tv on aux with a universal remote
Theres Either Gonna Be A Tv/Video Button On The Remote Or The Tv. Also Try Going To Channel 01 And Then Going Down A Channel To See If You Can Access The Aux Function That Way.
1helpful
Black square in lower part of tv screen
Turn off the text box function of the closed captioning.
1helpful
2answers
Problem with curtis cm27101s
This model has a history of defective capacitors in the vertical output circuitry. Have a technician change C824 a 10 uF @ 160V as well as C309 and C311 both 1uF @ 50Volt capacitors and your problem should be solved.
Top Curtis-Mathis Televison & Video Experts
ADMIN Eric
ADMIN Eric
Chi Chu
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
