Computers & Internet Logo
A
Anonymous Posted on Jan 31, 2013
Supermicro system initializing - SuperMicro Computers & Internet
Christopher Smith
Level 2:
Champion:
  • Expert 261 Answers
  • Posted on Jul 03, 2015
Christopher Smith
Expert
Level 2:
Champion:
Answers
261
Questions
0
Helped
64073
Points
404
The POST process is documented in the user manual under BIOS Post Codes.
What does error code 9AP mean
All questions need make and model and this appears to be a Computer or an Audi not a Washing Machine. There are 10,000 Categories to choose from.
Volkswagen Audi Group 9AP HKA Climatic air-conditioning system (semi-automatic)
SuperServer® - E100-9AP
Supermicro https://www.supermicro.com > MNL-1984 PDF If this item is enabled, the BIOS will automatically reboot the system from a specified boot device after its initial boot failure. The options are Disabled, ...
How to check service tag on supermicro servers
AFAIK Supermicro is not using Service tags like Dell or Lenovo. Instead they go by serial numbers. The location of the serial number depends on the type of the server:
Blade serial number (SBI... or SBA...) is located on the side
Blade Enclosure serial number (SBE...) is located on the rear side
CMM (chassis management module) serial number (SBM...) is located next to the latch
Rack-mountable chassis serial number is located on side of chassis by the sliding rail
4U Tower Chassis serial number sticker is located on the bottom side
Rack-mountable Systems' Serial Number is located at the rear side by I/O panel
Embedded Systems' Serial Number is located on the I/O panel
Check this website for more:
http://www.supermicro.com/support/SNGuide.cfm?sn=ss
What is system intilalization 2f
This is a video initialization error.
I have forgotten which one.
(I think the video RAM)
Check the graphic card, or the jumper on the motherboard, depending on the setup of the server. (On board video)
If on board video, also check the first DIMM pair.
Supermicro servers has not lan drivers installed.
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters could see a yellow question / exclamation mark? ! or a red X right click install drivers
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS)
press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
imake sure its enabledPci device arrows key scroll to nstalled.
http://www.xpdrivers.com/download-supermicro-motherboard-driver/_7_342567.cfm
Installation Instructions:
Click above Download link or Click here to begin installer download.
Click "Run" ("Save As") if using Firefox
Click "Run" Again
Follow on-screen prompts to complete installation.
Important: If you are using Internet Explorer as your browser, a browser Security Warning dialog box displays like the one below. You will need to click Run to install the application.
We recommend that you save it to your desktop and initiate the free scan using the desktop icon.
Should you choose not to save the application, you may simply initiate the free scan by clicking the "Run" button on the File Download Window.
hope this helps
Supermicro sata controller detects but won't initialize dvd
Make sure the DVD is last.
This means it is plugged into the highest number SATA connector.
The mother board will not post nor will the display initialize on a X7DVL-I Supermicro board.
Is the on/off button on the front of the computer-casing broken?
Take a volt-meter, and run a continuity-test.
Are the two wires from that button both properly connected to a pair of pins on the motherboard? If you disconnect the wires from those pins, and use a metal screwdriver to very briefly "short" the two pins, to simulate the pushing of the ON/OFF button, does the motherboard post? Do fans start to spin, or at least "twitch" a few degrees?
Have you tried a different power-supply?
Is there any lamp on the motherboard that lights-up anytime that
the power-supply is connected to AC power? Is that lamp on?
My supermicro mother board can not pick this type of SDRAM PC133U-333-542, meanwhile the memory slot is SDRAM
You are using the wrong memory.
A SuperMicro 370DLE only supports registered memory.
The U in the code shows that the memory you have installed is unregistered.
It will not work.
Exchange the memory for registered memory ,and the system should work fine.
Top SuperMicro Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Eric
ADMIN Eric
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
