Soltek SL-75FRN2-L Motherboard Logo
Anonymous Posted on Feb 09, 2009
Problem installing the 3 ram
I have a SOLTEK board type SL-75FRN2-L on which a have tried to mount a third ram, so far without succes, problem is that every time i insert the ram, regardless which slot, the PC refuse to start, it boot up, detect my HD and then stop, a few time it have reached the startscreen for Windows. At present I'm running with 2 ram, each 512 MB DDR PC3200 and would like to improve the performance just a little bit, the third ram is of course also same type hovewer not same brand.
I can supply more info i needed.
Hope my writting is understandable (I'm a Danish guy).
Regards,
Kjeld Nielsen
  • 2 more comments
  • Anonymous Feb 10, 2009
    Thanks to Nic61 for reply.
    I have been checking the manual and my MoBo support all above.
    Then I found an interesting articel and test of my MoBo on www.hardware.com - according to this test the MoBo are extremely sensitive to ram, only ram from SAMSUNG seems to work (see below)
    For the Soltek board SL-75FRN2-L, only Samsung RAM modules worked flawlessly. All other pairs of RAM from Kingston (using Winbond BH5, CH5 chips), TwinMOS (also with Winbond BH5 chips), Kingmax and Corsair failed our stability tests. Certain system-level benchmarks worked fine but when it came to stressing the memory and AGP bus, such as in 3D Mark 2001SE, the board simply dropped out of the test loop pretty quickly. This pair of Samsung RAM modules may have been the ticket to operability on our Soltek test sample, but some other nForce2 Ultra 400 motherboards we had in possession did not take to the Samsung RAM well. These are our findings from sample boards sent to us, but it seems that the retail motherboards too face this problem but not to the extent as we were affected. Still, the problem exists and great caution should be taken with your retailer to allow you to swap with completely different memory modules should you find your board not functioning stable.
    Only solution for me seems to be if I could find 2 pcs. ram, each 1GB as the MoBo works fine as long I only use 2 of the DIM. Finding these might be a problem but I will try.
    Regards,
    icepirat
  • Anonymous May 11, 2010
    SOLTEK has gone bankrupt.
    Their web-site is "down".
    So, there is *NO* "support" available from SOLTEK.
    Icepirat
    I wish you all luck in your search!
    Nic
      3 x 184-pin DDR SDRAM DIMM
        Supports DDR 200/266/333/400 DIMM Module
          Supports 2.5V DDR SDRAM
            Supports a maximum of 3GB of memory with 1GB DIMM
              Dual DDR Memory Architecture
            Thats what your mobo takes, check your sticks again and make sure they are supported as it says above. Otherwise it ont work.
            Nic
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1494
Points
Boot from 1 RAM at a time to see it theres a defective one...
Top Soltek Computers & Internet Experts
Paul Bade
Anonymous
Anonymous
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
