Epson Expression Premium XP-600 All-in-One Printer Logo
A
Anonymous Posted on Feb 22, 2013
EpsonNet setup, printer setup, error: installation failed (xp-600)
Printer has been working fine wirelessly till today, after reinstallation with USB-cable connected. Now trying to reconnect via Wi-Fi: Setup fails. Wi-Fi autoconnect (PC to printer) failed to setup (Epsonnet setup, printer setup), Error message: Installation failed Half-way the setup (printer setup) laptop looses wireless connection with modem/router.
2 Related Answers
Anonymous
  • 14 Answers
  • Posted on Oct 13, 2008
SOURCE: I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Anonymous
  • 564 Answers
  • Posted on Mar 12, 2009
SOURCE: printer settings ??
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Top Epson Office Equipment & Supplies Experts
Rommel Balcita
Grand Canyon Tech
Grand Canyon Tech
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
