I have a Dacor sealed burner 30" gas cook top the model number listed in the unit is GC30W
SOURCE: gas cook top
Most of the time when I come out for a service call with this problem, it is usually because the burner cap is not seated properly on the base. Look at the burner and make sure there are no uneven gaps. Most of the time you will have to rotate the burner cap till a notch or pin "seats" into place. Most burner caps just sit on the bases, and so they get knocked off or moved when the cooktop is cleaned or installed. Hope this helps!
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
SOURCE: SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
SOURCE: kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
