SOURCE: getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
SOURCE: Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
SOURCE: If you where going to Buy one radio which one would you Buy?
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
SOURCE: How to program an Icom IC-R5 handheld scanner
to store a fcy press BAND to go to your fcy range ie 118.000 airband
dial your fcy ie 127.900(shanwick ocean area control) press and hold V/M for 1 sec, small numbers now blink, dial the memory slot you wish to store into ie 001 then press V/M again for 1sec and this will store 127.900 into mem slot 001. make a list:-
mem number / fcy / mode(am - fm) / station / bank
to prog a fcy into a "bank", press V/M for 1sec - blinking mem numbers - dial mem number ie 001(127.900) press MODE - "bank" flashes past-
-- -- -- -- 001 shows, turn dial to show A-00 this is the first "bank", pressing BAND scrolls through all the alpha "banks" - choose one.. ie A-00 (for airband..) press V/M this puts mem 001 into "bank" A mem slot 00, there are 100 slots in each letter 00 to 99. do this to any fcy you want to scan as a group.
to scan a bank press V/M - small numbers appear -
press BAND to scroll through any "banks" you have created ie A B C D etc (only banks with fcys in will display), press MODE -"bank"- press MODE again and you will start scanning just that "bank" of mem slots.
MODE starts and stops the scan... each letter holds 100 mem slots.. happy scanning!!!
SOURCE: ICOM IC-28H very low sound from radio even thought volume is max
I had a very similar problem on a hand held scanner. In my case the mylar speaker cone had separated from the voice coil. I found an exact replacement for under $4 at Allied Electronics.
