Pool & Spa Logo
A
Anonymous Posted on Aug 20, 2017
Flashing CE CODE
A CE code continues to appear on display even after replacing ignition board with a burnt resistor. This time the CE code is flashing alternately with the actual water temp. I attempted to increase the desired temp but l it will not go over 70 then a CE code flashes and the desired temp goes back to 65 then it disappears. Then the CE code flashes again with the actual temp. PLEASe help!
5 Related Answers
Anonymous
  • 290 Answers
  • Posted on Oct 23, 2007
SOURCE: CE Code On 6 year old Calypso
Check the fuse on the motor control board and see if it is blown. If so, You could just have a bad board, but it may be a drive motor or pump motor. The most common thing is for the pump seal to leak into the pump motor and cause a short.
The CE code means the 2 boards can not communicate with each other so be sure to check the wiring connectors between them. Post back with what you find out.
Anonymous
  • 208 Answers
  • Posted on Dec 20, 2007
SOURCE: Toshiba e-studo120 H4 error code
This should do it.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Anonymous
  • Posted on Jan 11, 2009
SOURCE: Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Anonymous
  • 749 Answers
  • Posted on May 07, 2009
SOURCE: Minimaxpower on but fails to start no error code just flashes off
hi, it seems like a component malfunction, Try a hard reset Just unplug the power cord for 30 minutes or more, then try again.
Anonymous
  • Posted on May 17, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Top Hayward Pool & Spa Experts
john h
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
