SOURCE: I'm having troubles with parentheses. How can I enter: 2-(-2) ?
Most likely you're having troubles with the negative sign, not the parenthesis.
Press 2 - ( 2 +/ ) =
The "+/-" key is the key just to the left of the "=" key, used to enter negative numbers.
For this problem you don't need parenthesis. You can simply press
2 - 2 +/- =
But, what if there was a binomial instead of a single term outside of the
parentheses? That is, what if a binomial was being multiplied by another
binomial? An example of this is given below.
Now we will multiply the outer terms and again mark down the answer below the problem.
And the Inners.
And finally the last terms.
