SOURCE: Vollrath induction cooker is not working. The display reads F9. Model # is 59500.
The range does not recognize the pan material. Only ferrous (magnetic) cookware will work with induction. This is a protection circuit to only heat proper cookware. When all else fails read the instruction book or call the service department for the manufacturer...save time, reduces frustration and assures safe operation. Good Luck
SOURCE: My neolife induction cooker model 1602 shows E0
E0 means incomming voltage is higher than 260 V.
SOURCE: E1 error was shown on
Possible that the driver of the induction coils is short or damaged. You might need to remove the panel and check within to see the reason for the protect cut off.
If there is no other display on switch On then the circuit is faulty and a knowledge of power electronics is needed to probe into the circuit.
SOURCE: I am using Pigeon induction
your cooker has a low or high voltage problem.
check your plug and clean all parts inside your cooker.
maybe have some corroation in connectors and terminals.
