Always happens when streaming tv shows (netflixs)
SOURCE: debug assertion failed
For solving you problem do the following
1. Re-Install the IE latest Version and also my suggestion is that to install the Opera latest version
Let me Know that you problem is solved and rate me as Fixya!
SOURCE: I am getting error messages when attempting to view links on Int. Explorer
Hi, give this page a read and see if it helps fix your problem:
http://help.lockergnome.com/windows/SysFader-iexplore-exe-Application-Error-ftopict533700.html
Let me know if it works.
SOURCE: No icons, start menu, taskbar, explorer not working
backup your data and do a repair install - might take a while longer but at least you know it will clear any issues.
there are a number of things you can do to fix it but will most likely take a lot longer
SOURCE: pc infected with dumprep.exe
reinstall your operating system
if you dont have cds most are on the back up of hard drive
when first boot up, press control and f10 or f11
should take you into system recovery
Error Report, C:\DOCUME~1\Owner\LOCALS~1\Temp\5995_ _appcompat.tx
