Fuji FinePix S1000FD Digital Camera Logo
Posted on Mar 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FOCUS ERROR Lately,on powering on my camera (FINEPIX s1000 fd) I see "FOCUS ERROR" on the screen and the camera does not function. This camera used to work fine earlier.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Fuji Master 102,366 Answers
  • Posted on Dec 25, 2012
Fuji Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10724326
Points
622696
5 Related Answers
A
Anonymous
  • Posted on Jan 18, 2008
SOURCE: focus error
hi i need help with my focus errar
A
Anonymous
  • Posted on Mar 03, 2008
SOURCE: s56oo fuju finepix camera focus error
ha right now i have the same problem and like everyone else i havent dropped it or damaged it.
Fuji being awesome as they are wont cover this in warranty and its about $230 + to get it fixed and reportedly comes back with more errors than before
so how about you try what i'm about to do and smash it with a hammer, in future try canon or something else.
I am now a photographer without a camera for two months my camera is barely a yr old.
Thank you fuji!!!
Anonymous
  • Posted on Oct 29, 2008
SOURCE: I have FOCUS ERROR ON MY FUJIFILM FINEPIX s6500fd CAMERA
This is just a suggestion, as I am not an expert.A couple of years ago I had a problem with my older, Fuji Finepix camera related to the computer downloads/programming and I found Fujifinepix web site. I sent them an email and they responded and did not charge anything. Could try that..
Anonymous
  • 5 Answers
  • Posted on Feb 21, 2009
SOURCE: focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at worldin1@gmail.com
Anonymous
  • 2761 Answers
  • Posted on Sep 10, 2009
SOURCE: fuji finepix s1000 zoom error lens is stuck out what can I do???
If you recently dropped the camera, you may have damaged the lens housing -- that will require professional repair. Otherwise, your problem may be as simple as low batteries or corrosion on the battery terminals inside the camera. Make sure that the batteries are fresh/fully charged. If the problem persists, remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and replace them in the camera. This cleaning works about 90% of the time, and I hope it clears up your problem.
Top Fuji Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Rommel Balcita
Are you a Fuji Camera Expert? Answer questions, earn points and help others
