Computers & Internet Logo
Anonymous Posted on Jun 03, 2013
Java jre1.7.0_05-c missing file
Lars Olsson
Level 3:
Brigadier General:
  • Lenovo Master 3,400 Answers
  • Posted on Jun 03, 2013
Lars Olsson
Lenovo Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1064354
Points
10330
UNINSTALL ALL JAVA.LOOK IN C:\ AND REMOVE ALL JAVA.AND INSTALL A FRESH COPY OF JAVA
AFTER UNINSTALLED THE OLD JAVA REBOOT. IT'S NEVER WRONG.
1helpful
WHEN I DOWNLOAD JAR FILES IT SHOWS INVALID FORMAT
It looks like a Java application is missing or corrupt in the handset. Java ARchive files need a program to process them and they are different on mobile phone applications. The phone might just be in need of a software update or it might be a more serious problem like physical or liquid damage (I hope not).
Apr 01, 2011 • Cell Phones
19helpful
2answers
Unable to access jarfile lib\MP3Rocket.jar
the error refers to a missing mp3rocket.jar file within the installation of mp3 rocket. i.e. C:\program files\mp3 rocket\lib. solution is: uninstall mp3 rocket and uninstall all versions of java and JRE from add and remove programs(XP) then restart. install a new version mp3 rocket and you will be prompted to download java again. once installed MP3 Rocket.exe should be restored
1helpful
Have removed java updates and now operating slowly, when i have tried to download java again i am getting error codes 25099 and another error 2753.regutils.dll, think i have unintentionally removed...
Hi! the error it self highlighting "regular uitlity" concept in dll name. there is no problem with automatic java updates, but may be missed connection of updates path, so try think about it there would be no problem at all with java updates and operating system..
Dec 13, 2009 • GPS
1helpful
Facing Problem while downloading gmail java app for mobile phones. i have tried on multiple phones to download the Gmail Java Application for my mobile phone. but when ever i click the download link, i get...
Hi friend I believe the download file is missing, please could you re-upload this file.
In fact Its depends on your phone. Follow below link to find the best solution for your mobile depending on brand you using
http://www.google.com/mobile/#p=nokia_smart
Thanks.
Sep 24, 2009 • Cell Phones
2answers
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
1helpful
Installing java applications and games
hey first of all you need a .jad file for all the java files.
download jad maker from here
http://www.brothersoft.com/jadmaker-25179.html
drag and drop the java files to the jad maker window to create a jad file for that particular java file.
once you're done copy both the java and jad files to the "other files" directory on the phone.
Now exit all menus and type in this code: *#9998*4678255#.You should now get a 'Activated' message. [This is to enable java installation.]
Then go to the other files directory where you placed the jad and java files. Open the .jad file and then click install.
Once the installation is done you can disable java installation by re-typing that code again.
1helpful
3answers
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Missing java settings
best place to start is with the phone web site for updates see if they reinstall the java missing http://sonyericsson.com/cws/
or email them.
riz.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
