Linksys WRT54G2 Wireless Router Logo
Posted on Mar 22, 2009
Install router dsl - Linksys WRT54G2 Wireless Router
  • JDTec
    JDTec May 11, 2010
    You need to set it for PPoPe and put in your DSL: usename and password.
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Mar 29, 2009
Anonymous
Contributor
Level 1:
Answers
27
Questions
0
Helped
37272
Points
43
Go to http://www.linksysbycisco.com/US/en/support/WRT54G2/download
Then select the version 1.0 under please select your version
After that you need to select Setup wizard for win xp - on the left bottom side
Dsl modem = to 3 linksys wrt110 routers for wi-fi ?
What you are trying to do is a rather big job. Hire a company to connect the equipment properly. The headaches you save will be your own. If you install it, you will have to fix it everytime it goes out if you contract someone to install it and you buy a support contract when they install it, THEY get to come fix it and the headache is theirs, not yours. And NEVER install that type of router in an attic, they will overheat and fail very quickly.
How to instal lrouter
plug your DSL or ISP cable in your router's WAN or DSL port and then you need to power on your router.
I just installed dsl and want to use it with my existing router and the router doesnt want to work with the dsl ...help what do i do ???
First, make sure the dsl is working by connecting it to your computer directly.
Next, turn the router off, turn the dsl modem off, connect the dsl modem to the router. Start the dsl modem first, then start the router, then start your computer and try to connect.
2answers
AT&T just gave me a new Motorola DSL box and I can't get my router to even find the internet which is active. I can only get the router install portion to go just to where it can't find the...
First of all using the Router Install Portion try to do a 'factory reset' or a 'reset to default'  - wait for a reboot to see if any change occur.
Next try to use the cable between your Moto Box and your LinkSys Box in a different port on the link sys. It may sound silly, but it can work very well sometimes.
Nick
Install router on windows XP
you could download the quick start from linksys.com for that but basically there is no installation necessary with windows, it's a network device that does not need to be installed. simply plug it in.
2answers
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Need the installation drivers
The Westell 327W (VersaLink) combination DSL 'modem', router and wireless access point will, for most people, be supplied with their new DSL service. Were you using a DSL service and suspended or disconnected? You should still have the drivers in your original computer. If not, the DSL people will install from their side.
I'll keep looking for you.
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
2answers
Lost internet connection
Power off the router by unplugging it. Also power off the DSL or cable router. Shut down the PC. Located on the back side of the router is a small reset button. Using a pen press and hold for ten seconds. Same for the DSL or cable. Power every thing back up starting with the DSL/cable, than the router and lastly the PC.
Siemens Speedstream 2624
Find the reset button on the rear panel of the wireless device and follow the factory reset instructions below: 1. Power Off the router. 2. Hold the Reset Button down while you Power On the router. 3. Continue holding the Reset Button until the Status (Red) LED blinks TWICE. 4. Release the Reset Button. The factory default configuration has now been restored, and the Router is ready for use. The DSL/Cable Router's default IP Address is 192.168.254.254 To establish a connection from your PC to the DSL/Cable Router: 1. After installing the DSL/Cable Router in your LAN, start your PC. If your PC is already running, restart it. 2. Start your Web browser. 3. In the Address box, enter "HTTP://" and the IP Address of the DSL/Cable Router, as in this example, which uses the DSL/Cable Router's default IP Address: HTTP://192.168.254.254 The first time you connect to the DSL/Cable Router, the Setup Wizard will run automatically. (The Setup Wizard will also run if the Router's default settings are restored.) This should get you in the right direction. ZT3000 "Beta tester of "0"s and "1's"
Top Linksys Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
