Anonymous Posted on Jun 08, 2013
100 to binary - Office Equipment & Supplies
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Jun 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
2902
Points
18
Click B/b (binary) mode and enter your binary number. Then press D/d (decimal) mode to see the result.
Describe the difference between binary semaphores and counting semaphores.
Binary semaphore is a semaphore with the integer value ranges over 0 and 1 whereas the counting semaphore's integer value ranges over unrestricted domain. Binary semaphores are easier to implement comparing with the counting semaphore.
Binary semaphore allows only one thread to access the resource at a time. But counting semaphore allows N accesses at a time.
The 2 operations that are defined for binary semaphores are take and release.
The 2 operations that are defined for counting semaphores are wait and signal
I AM TRYING TO UNDERSTAND BINARY
Where to start. Most things we do in math are in base 10, probably because we have 10 fingers. Instead of base 10, binary is base 2. In computers, binary rules because a bit can be set to ON or OFF, 1 being ON, and 0 being OFF.
So the next thing is counting. 0 1 10 11 100 101 110 111 1000 1001
Decimal equivalent 0 1 2 3 4 5 6 7 8 9
How to convert from binary to decimal? Line up the columns and multiply down. For example, 1101. The columns, starting from the right are 2^0, 2^1, 2^2, 2^3, reading ^ as exponent.
See if I can line these up. 1 1 0 1
2^3 2^2 2^1 2^0
8 4 2 1
multiplying down 8 4 0 1
Next step is to add them up. 8+4+1 = 13!
Going the other way, we have to divide by the largest 2^x number, so what is left over and continue dividing until nothing is left.
For example, 56. 2^5 (32) is the largest 2^x number that goes into 56, so we put a 1 in this column. Our remainder is 24. 2^4 (16) goes into this once, so we put a 1 in this column. Our remainder is 8. 2^3(8) goes into this once, so we put a 1 in this column. Now the remainder is 0 so we put a 0 in the 2^2 (4) column, 2^1(2) column, and 2^0 (1) column.
We end up with 111000.
Let me know if you have any questions.
Good luck.
Paul
Source code for binary addition
You have the wrong forum, this is a car and truck forum.
For binary integers on the TI Nspire what is the maximum number of binary digits?
I was able to enter 64 binary digits without getting an argument error. with 65 binary digits and higher one gets the error.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
