DEI Python 1400XP Remote Start/Keyless Entry System Logo
Anonymous Posted on Mar 22, 2009
Installation Problem python
I just can't get it to work on my 2006 Silverado. My problem is that I don't know which wire goes to the VATS bypass from the unit. The manual says a blue wire, but it I have tried both blue wires and it tries to start three times and shutsdown. The manual indicates this is a problem with the 555L bypass.
  • Anonymous Mar 29, 2009
    The blue wire is connected correctly. Truck starts with key and starts with remote with key in ignition turned on.
Anonymous
Level 2:
  • Expert 43 Answers
  • Posted on Mar 28, 2009
Anonymous
Expert
Level 2:
Answers
43
Questions
Helped
24515
Points
114
First things first with the 555L installed will the truck start with the key if not then the 555L was not installed correctly if the truck will start with the key then the next step is to use the blue wire coming from the satelite relay box to connect to the 555L I will look for your response.
  • Anonymous Mar 30, 2009
    ok the wires that are used in that vehicle are as followed:
    Red +12-
    connect to red wires on satelite relay box
    Pink +12 volt ignition connect to pink wire on satelite relay box
    Pink-White +12 second ignition connect to white wire in ignition harness
    Orange +12 volt acc connect this wire from the relay box to the orange and brown wires on the ignition harness
    Last wires are the green and purple
    Green connects to the key side of the yellow wire on the ignition harness
    Purple wire connects to the starter side of the yellow wire
Top Directed Electronics Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
