LG Art Cool LA181CNW Split System Air Conditioner Logo
Anonymous Posted on Jun 12, 2013
Temp Control Problems
Unit runs non-stop. Does not respond to temperature settings. Operation modes have been checked. Reset remote also. No change in operaion, rooms are very cold, usually in the mid 50's
Humphrey Sambo
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Feb 03, 2014
Humphrey Sambo
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
6
Questions
5
Helped
2304
Points
7
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
3 Related Answers
Anonymous
  • 958 Answers
  • Posted on Jun 24, 2008
SOURCE: LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Anonymous
  • 400 Answers
  • Posted on Mar 20, 2009
SOURCE: lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Anonymous
  • 455 Answers
  • Posted on Oct 26, 2010
SOURCE: I have a 18000btu LG
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Top LG Heating & Cooling Experts
Sudeep Chatterjee
Sudeep Chatterjee
Paul Bade
Frank Fernandez
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
