Frigidaire ATF6000ES Front Load Washer Logo
Anonymous Posted on Aug 26, 2007
E20 Error code
My washer has an error code of E20, the water won't drain and I suspect it is plugged. How do I unplug the clog? Thanks
  • 1 more comment
  • Anonymous Aug 27, 2007
    Do I go in from the back of the machine then? Is there a trick to remove it? Thanks so much!
  • sugardmom Dec 09, 2008
    I GET A E20 ERROR CODE WHEN MY WASHER HAS BEEN ON FOR ABOUT 10 MINUTES IM NOT SURE WHAT THE PROBLEM IS BUT IT DOESN'T DRAIN EITHER
  • Anonymous Mar 24, 2014
    do i have to turn water off to take all drain hoses off??
Anonymous
Level 3:
  • Master 641 Answers
  • Posted on Aug 27, 2007
Anonymous
Master
Level 3:
Answers
641
Questions
Helped
964288
Points
1616
It could be a defective or plugged pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in the pipes connected to it. Goog luck!
    To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the right side of the bottom of the machine, but with the unit tipped on its front it's easier to remove it through the back than through the bottom of the washer.
    Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them.
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
