Trying to connect wii to the internet
SOURCE: error 52030 in internet connections
Are you using a WEP? If so, it will only connect using KEY #1.
SOURCE: I have an Error Code 52030 on my WII. What does
it means that u are trying to connect to wifi but there is no wifi around so go 2 tech support for wii and enter the error code.:)
SOURCE: Trying to connect my Wii
Error
Code: 52030
This error code
usually indicates a problem relating to wireless security. Please try
the following troubleshooting:
Try a "Manual
Setup" with the Wii console (how
to), using your network's IP configuration settings. To access
these settings:
SOURCE: my wii will not connect
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
SOURCE: Unable to connect to cox internet on tv using wii
It appears your internet is not set up correctly. It most likely means your wireless internet security key is incorrect. You can follow this solution from Nintendo:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
i dont know how to connect my wii to th internet because i want to send messages and use wii shopping bchanel
