Hello Billy, I understand your unit is displaying error code
E13. Here are a few troubleshooting tips that
may help you get to the root cause:
First, be sure
that your tub is not overloaded. Sometimes when overfilled, water can and will
slosh outside of the unit.
If the tub is not
overfilled, check your hoses and other connections. Like most laundry units,
there is always some vibration associated with the functionality of the
machine. As the appliance is used over time, hoses and other connections can
loosen and begin to leak. Be sure to secure any loose connections.
If the above
items did not assist you in resolving the issue, it could be a number of other
underlying causes - primarily an electronic pressure sensor, switch or the
unit's main control board. These parts are commonly replaced by experienced
service technicians.
Hello friend, that's a great question!
Based off what you have provided your Frigidaire oven is displaying an error code of "E13" and you would like to know what is causing this problem. The error code "E13" stands for a bad EEPROM (Erasable Programmable Read Only Memory) and this could be an issue with the UIB (User Interface Board). This electrical component may need to be replaced however this is not a simple DIY job. I would recommend speaking with a professional technician for proper diagnosis and repairs. This will prevent you from making unnecessary part purchases. -Matt
