Casio FX-115ES Scientific Calculator Logo
Anonymous Posted on Aug 29, 2013
How do you change a number to binary? - Casio FX-115ES Scientific Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Casio Master 102,366 Answers
  • Posted on Aug 29, 2013
Casio Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10724326
Points
622696
Press MODE 4 to select the BASE-N mode. Press one of DEC, HEX, BIN, or OCT to specify the input base, enter the number, then press one of the base keys to convert to that base.
How to change a decimal value to binary number in fx-85GT PLUS ? Thanks!!
Let's do the preocess so it will work on any calculator.
As an example, convert 68 from decimal to binary.
The decimal columns are 10^0, 10^1, 10^2, 10^3, etc.
The binary columns are 2^0, 2^1, 2^2, 2^3, etc.
Flipping to the normal left to right, we get 2^6, 2^5, 2^4, 2^3, 2^2, 2^1, 2^0.
64 32 16 8 4 2 1
We divide our number, 68, by 64, and get 1 with a remainder of 4. We next divide our remainder by 32, 16, 8, and finally 4, where we get 1 with no reminder.
In binary, this works out to 1000100. To check, we multiply the ones by the respective column values and get 64 + 4 = 68.
Good luck.
Paul
1helpful
2answers
Convert to binary to a decimal 111000
To convert from binary to decimal, we have to line up the numbers with the binary columns.
1 1 1 0 0 0
2^5 2^4 2^3 2^2 2^1 2^0
32 16 8 4 2 1
32 + 16 + 8 + 0 + 0+ 0 = 56
Good luck.
Paul
2answers
To show me how to break the number 127 to binary form
Let's start by setting up the binary columns.
2^0 = 1
2^1 = 2
2^2 = 4
2^3 = 8
2^4 = 16
2^5 = 32
2^6 = 64
2^7 = 128
Written horizontally.
128 64 32 16 8 4 2 1
1 1 1 1 1 1 1
What is the biggest number that goes into 127. 64. Put 1 in the 64s column. 127 - 64 = 63.
What is the biggest number that goes into 63. 32. Put 1 in the 32s column. 63 - 32 = 31.
What is the biggest number that goes into 31. 16. Put 1 in the 16s column. 32 - 16 = 15.
What is the biggest number that goes into 15. 8. Put 1 in the 8s column. 15 - 8 = 7.
What is the biggest number that goes into 7. 4. Put 1 in the 4s column. 7 - 4 = 3.
What is the biggest number that goes into 3. 2. Put 1 in the 2s column. 3 - 2 = 1.
Put a 1 in the 1s column.
So we have 1111111 in binary.
Good luck.
Paul
2answers
How to convert octal numbers into binary numbers
Each octal digit represents three binary digits. Simply convert each octal digit to three binary digits and string them together.
0o = 000b
1o = 001b
2o = 010b
3o = 011b
4o = 100b
5o = 101b
6o = 110b
7o = 111b
As an example, to convert 351o to binary:
3o is 011b
5o is 101b
1o is 001b
so 351o is 011101001b
2answers
How to convert a binary to text
Letters can be converted into decimal number using ASCII table. Every Character has it own equivalent number. Once converted into decimal (base 10), I could be easily converted into binary (base 2)
You could also use applications or web based applications such as ASCII to binary converter to help you convert it.
1helpful
How to convert binary with point to decimal
1) Look at the following numbers before trying to convert binary to decimal. Each of them represent the value in a binary number from left to right.
128-64-32-16-8-4-2-1
2) Look at your binary number, for this example lets use 10010010. For each one add the corresponding number from step 1, the number you come out with is the conversion.
So: 10010010 -> 128+16+2 -> 146
10010010 = 146
For binary integers on the TI Nspire what is the maximum number of binary digits?
I was able to enter 64 binary digits without getting an argument error. with 65 binary digits and higher one gets the error.
1helpful
How do I convert from decimal to binary?
change your mode to binary , then enter your decimal no in dec link and then press bin link you can get the binary equivalent
Top Casio Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
