There are two things you can do. The first being that when you updated Java did you download some unwanted software? To check look down your list of installed software. Keep your eyes open for anything that looks odd, especial if it's called "Motion Reality". If you find that click the remove button.
If you can't find anything, do a system restore, set it before the update. That should restore your computer. You can try again for the Java update. But if it does it again restore and contact Java.
SOURCE: Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
SOURCE: Toshiba M305D issue with online videos
Try to update your flash player here: http://www.adobe.com/products/flashplayer/
Hope that helps
SOURCE: internet streaming audio problems
At this point I would suggest doing a fresh install of the windows operational system, or if you can remember when the problem started with the last download or updates that may give a clue where to look, finally try a system restore if you can back date it far enough.
Nothing unusual found in the installed software. System restore didn't fix the problem. Contacting Java directly is difficult and costs money. Does anyone have any other suggestions?
There is a piece of software out there called Motion Reality 3D Viewer, which has a free version. It's possible that when you update the Java then this was a "free" option that you didn't cancel. Or if you have download any free software then it might have been attached. However the website says that the program is called "SessionViewer.exe" so search for that on your list of installed programs. Here is also the website link for it:http://motion-reality-3d-viewer.software...
