How would I factor on a TI-86?
The TI 86 calculator does not manipulate algebraic expressions. If does not have a Computer Algebra System or CAS. Try the TI 89 Titanium, TI92/92PLUS, Voyage 200 PLT, TI Nspire CAS, TI Nspire CX CAS. In Casios you have the ClassPad series (300, 300Plus, 330 Plus and the latest 400. The ClassPad 400 has a color screen. It is also orientable portrait or landscape. Other Casios are the Algebra FX 2 and 2, and the FX 9860 G Plus/ SD. In HP you have HP 50G, HP49C, HP49G+.
SOURCE: Can you Factor on a TI-84? IF not, does the TI-89?
Well, to answer part of your question, yes... the TI-89 does factor like this. it is inputted like this:
factor(6*x^2+11*x+4,x)
Check the catalog in the TI-84 (which is 2nd-zero) and look under F for factor()
SOURCE: Send program from one TI-86 to another TI-86
First, connect the two calculators with the unit-to-unit cable.
Prepare the receiving calculator: press 2ND [LINK] F2.
Select the item to send on the sending calculator: press 2ND [LINK] F1 F2. For each program you want to send, navigate to it using the up/down arrows and press F2. Press F1 to send.
