HP Mini 1000 Netbook Logo
jessy lim Posted on Sep 23, 2013
Java install - HP Mini 1000 Netbook
RM-technology
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 36 Answers
  • Posted on Nov 25, 2013
RM-technology
Contributor
Level 1:
New Friend:
Cheetah:
Answers
36
Questions
0
Helped
5307
Points
46
You need to go here : https://java.com/en/download/index.jsp
2answers
Game won't load because I don't have Java and Java won't download because the site is unsafe.
If it is a Genuine Java site and you feel confident, you might have to allow Java access to your tablet or PC in order to download & install.
Remove old Java and Install new Java
to remove java you must go into control panel and find either add/remove programs or uninstall programs. then click remove or uninstall on all Java platforms that show up in the list of programs. JRe is also Java, don't forget those. then goto Java.com to install the latest version.
It keeps saying enable javascript which I did and it still will not install
The first thing to try is to uninstall and reinstall Java.
1. Enter Windows key + R, which will open the Run dialog box.
2. Type APPWIZ.CPL into the dialog box and click OK.
3. Wait for the Programs and Features (Vista and 7) or Add and Remove Program (XP) page to completely load.
4. Scroll down looking for any JAVA installations.
5. Select and remove any and all JAVA installations.
6. Restart computer if necessary.
7. Follow this link to install the latest version of JAVA: http://www.java.com/en/download/index.jsp
8. Click "Free Java Download" and download Java.
9. Install Java and restart computer if necessary.
Note: If you have difficulty downloading and installing Java, then try and use Internet Explorer to install Java.
Hopefully this fixes your problem. If it doesn't, then please post back.
Good luck and thanks for using FixYa.
I can't add arabic language to my computer
How to Install Java in Windows XPProfessional
Java is one of many third-party applications that enhance your experience onyour Microsoft Windows XP Professional operating system. Java, developed by SunMicrosystems, is a programming language and computerplatform that is the backbone behind many of the programs you use today,including games,businessapplications and utilities. Software developers choose the Java platformbecause it has been tried and proven to work the best. Java publishers focus onperformance, stability and security. It's easy to get the latest version ofJava and install it on your XP Professional system.
1. Manually download. Visit the Java site to download the Java application;ensure the version is Windows XP compatible. If you have a 64-bit Windowsoperating system, pay special attention to the download; most Windows usershave 32-bit by default. Save the file to a location that can easily berecalled. 2. Begin installation. Close anyopen Web browsers and applications. Click on the saved Java download file.Click "Run." Read any warnings and agreements. Acknowledgeconfirmations as you proceed, selecting "Next" until eventuallygetting to the "Install" button, and click that as well. 3. Read intermediateinstallation messages. As the main Java application installs, you may encounteradditional advertisements. Read, make decisions, and click the "Next"button to proceed. A "Progress" window will indicate "Status:Installing Java." 4. Verify installation. Afterinstallation is complete, the Java setup window will show "You havesuccessfully installed Java." Click the "Close" button and resumeusing your PC per usual.
5. For additional verification that Java was installed, refer back to theoriginal page from where the application was downloaded. Find the link"Verify Now." Click it to advance the page, and select the red"Verify Java version" button. Wait while the Web page verifies theversion.
TIPS and WARNINGS
After first-time Java installation, the application can be accessed from theWindows XP Professional "Control Panel" on the "StartMenu." After opening the app, click on the "Update" tab toretrieve the most recent version of Java.
It is important to keep Java on Windows XP Professional systems updated forsecurity reasons as vulnerabilities might exist in outdated versions.
Read more: How to Install Java in Windows XP Professional 'eHow.com
Java installation problem
How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
Error: 25099 during Java installation This article applies to:
  • Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
  • Browser(s): All Browsers
  • Java version(s): 6.0 , 6u10+
SYMPTOMS
While Java installation is in progress, a message box with the following error is displayed:
Error 25099. Unzipping core files failed.
CAUSE
The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
2answers
Java won't load on my computer
id suggest that you uninstall java and delete the folder from the hard drive after you uninstall it from the computer, and then clean the registry of any instances of old keys associated to java,then redownload and reinstall java fresh,be sure its the right version for your Vista ( home,Bussniess) Hope this Helps Steve
2answers
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
  1. Go to Java.com
1helpful
Installing java applications and games
hey first of all you need a .jad file for all the java files.
download jad maker from here
http://www.brothersoft.com/jadmaker-25179.html
drag and drop the java files to the jad maker window to create a jad file for that particular java file.
once you're done copy both the java and jad files to the "other files" directory on the phone.
Now exit all menus and type in this code: *#9998*4678255#.You should now get a 'Activated' message. [This is to enable java installation.]
Then go to the other files directory where you placed the jad and java files. Open the .jad file and then click install.
Once the installation is done you can disable java installation by re-typing that code again.
1helpful
Can't update Java 1.1.4. Can't view Java or Suns web sites
Use JavaRA:
http://raproducts.org/
Works great for getting rid of older Java installs. Has links to the Java update pages inside the program too.
Also, try installing Firefox and use it to download Java installer.
Java jre installation not complete
Hi There,
As i understand you receive an error when you run the installed program.
Please uninstall the complete downloaded software and reboot the PC. Then download the latest Java JRE (Java Runtime Environment (JRE) 6 Update 7) to run all Java programs from the link given below,
http://java.sun.com/javase/downloads/index.jsp
Once you have installed the Java JRE, again install the program and test if it works.
It will work!!
Regards,
Olafsson.
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
