Health & Beauty Logo
A
Anonymous Posted on Sep 28, 2013
Replace joliet insole - DR Scholl's Health & Beauty
2answers
What's the zip code to Joliet Illinois
60431,60432,60433,60434,60435,60436
Mephisto moblis replacement insoles for sandals size 40
I would get in touch with Mephisto resellers and see if they are available. If not, a good quality shoe repair shop can source them or make them for you.
Can the insoles be replaced after they collapse
Absolutely. better quality shoe stores have replacement insoles that you can select.
2answers
Squeaky noisy sneaker
it's very simple. just take out the insole from the sneaker, then put some talcum powder in the sneaker, then put the insole back. this will eliminate the squeaking.
the problem is that sweat gets between the insole and the inside surface. the friction between the two is the cause of the squeaking.
What kind of insole can I use for dress shoes?
You need thin insoles for dress shoes. My favorite is the Pedag Leather Insole. My best friend swears by the Spenco Arch Cushion.
What insoles can I use for flat feet?
I use posture control insoles for my flat feet. They are made especially for flat feet. they help with problems with balance as well as general foot problems caused by flat feet.
If i work about 10 hours a day how long will Dr. Scholl's Work insoles last for?
I would say at least for 4-6 months. I wear them for about 12 hours/day and thats how long they generally last for me.
2answers
How do you change battery in Carter's kids light up shoes
There is a battery in the insole. Lift the insole and the battery will be in the heel
1helpful
I have a pair of brand new ecco shoes. Finally convinced my grade 12 daughter to pair the price and buy well made shoes. They are a purple leather lace up shoes. They make airy sounds with ever step....
I've had this problem with my daughter's shoes, and her foot is very narrow. I cut down some generic-brand Dr. Scholl's-type insoles (available at grocery and drugstores) and that did the trick.
1. Get the appropriate sized insoles, and lay the right show on the right insole, and the left shoe on the left insole. Trace them with a pen.
2. Cut out the insole, cutting slightly inside the lines-- the inside of the shoe is smaller than the outside.
3. Work the insoles inside the shoe. Use your fingers to feel around the edges to see where you need to trim them to fit.
4. If it's too long, don't trim all the length off the toe, or all the length off the heel... you'll mess up where the arch curves.
Good luck! I hope it works for you.
Top DR Scholl's Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Cathy
Level 1 Expert
Anonymous
Level 1 Expert
Are you a DR Scholl's Health and Beauty Expert? Answer questions, earn points and help others
