SOURCE: Sanyo VWM-170
Try 000 or u have to get the softcopy of the manual for your product in
http://www.sanyo.com/
Thank You
SOURCE: sanyo vcr player vwm 900, tape won't COME OUT.
This needs a little bit of care but essentially you will need to unplug the power from the VCR then do the following:
Remove the top cover
Then with the front of the VCR facing you look to see if any of the tape is wound around a large metallic silver drum, that is tilted upward and is not flat, at the rear of the tape casing. If so then it means that it has wound around the drum and you will need to retrieve the tape to allow the eject mechanism to work. Do not touch the shiny polished part of the drum. To get the tape in usually means that you have to locate a plastic or metal cog wheel, usually on the right side of the VCR that you can turn with your finger. This makes the VCR motor move. Also there is one that works the tape eject mechanism. If you can find the one to wind in the tape before working on the one for the tape eject than you stand a chance of rescuing the tape, if not then it will get some damage. Don’t worry about turning the cog wheels with your finger as you can do very little harm to the VCR with no tools involved and no power on. Moving the cogs this way will only cause very small movements with the tape motor and eject so you will need to be a little patient and you will soon see what is happening. Once remove run a cleaning tape through the VCR before you use it again. With the limited space available her it is difficult to give you much more info.
SOURCE: what's the universal remote code for the sanyo
Try these: 1022, 1045, 1047, 1070, 1131, 1172, 1192, 1203.
SOURCE: Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
