1. Push
in indent (illustration 1) on hand wheel disc. This will stop
the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over
rim of spool to prevent thread from tangling.
1. Push
4. Lead thread passing
it first through the lower slot of the thread guide. Next
through the upper slot, leading the thread to the right and
around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension
disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim
of bobbin.
8. Holding thread end, step on
speed controller to run machine until desired amount of thread
is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from
bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its
original position. If necessary, turn hand wheel to engage
needle movement.
