Xerox DocuPrint N40 Laser Printer Logo
Posted on Sep 25, 2007
Asterisks in display
When powering on the printer, printer initalizes. It displays the "version" and it doesn't appear that any faults occurs. Then a single "*" apppears in the display. A short time later the display fills with "*"'s and the on-line indicator goes green, but the printer goes no further. The asterisks stay in the display and the "READY" state is never reached.The printer was working fine until netware was disabled and the printer re-booted.
  • PrinterSlave Jun 06, 2008
    My Xerox DocuPrint N40 several times jamed first. But it made this broken gear noise after I took out the last jammed sheet. I removed the tone cartridge and the fuser to see if I could see any broken or damaged gears. I found none. I put all the parts back and shut the door, no noise started. One minute later I looked at the screen and saw "Sys ERR OU476 Power Off & On" on the display screen. I restarted the printer. First a single * appeared, then followed by several * in a row and then it returned to the "Sys ERR OU476 Power Off & On" with the Online & fault lights on as well as a blinking Data light.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
101
Points
Had the same problem: took the tray away and found a sheet of paper in the printer not alawing
the tray sensor to work properly!!! after that the prob was solved.
Top Xerox Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
