Canon Pixma iP6600D InkJet Photo Printer Logo
A
Anonymous Posted on Oct 18, 2013
Error code 41 - Canon Pixma iP6600D InkJet Photo Printer
What is error code 41
Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
1helpful
What's the actual meaning of DTC codes 41, and 58, for this vehicle?
the meaning of codes 41 and 58 is:
DTC - 41 Ignition control error
DTC - 41 MEM- CAL error
DTC - 41 Cam sensor sinal error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS System error
I hope this is helpful
Brother all in one mfc-255cw error 41 when trying to print across network
While there are many ways to prevent Brother printer error code "41
5helpful
3answers
41 device error
i have a problem 41 device error in the toshiba dp80f
Mitsubishi 52525 error code 41
Replace the power board thats what causes the Short error 41
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
