Maytag M7DH45B2A Dehumidifier Logo
D
Donald Cooper Posted on Oct 20, 2013
Code: CH 67
"bucket full" light blinking, code: CH 67 displayed...Suggestions?
robotott
Level 1:
  • Contributor 21 Answers
  • Posted on Oct 21, 2013
robotott
Contributor
Level 1:
Answers
21
Questions
0
Helped
8444
Points
35
Bucket switch/float valve sticking? Take out the bucket and make sure the switch moves freely.
Bucket full light blinks with display code of 01 when bucket is empty
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
It stopped working. One display reads "CH" and
heatman101
UNIT ICED UP. TEMP. IN CRAWL SPACE ABOVE 60 DEGREES. AFTER DE-ICING UNIT IT RAN FOR A WHILE AND THEN STOPPED. IT SHOWS CODE CH 01AND THE BUCKET FULL LIGHT IS BLINKING, NOT STEADY ON. POWERED DOWN UNIT...
When you powered down the unit, did you just turn if OFF using the controls on the unit Or did you unplug it entirely? If you didn't unplug it, it won't reset itself. Leave it unplugged for at least 30 minutes. As far as the blinking bucket full light is concerned ... It's possible that the bucket is slightly out of kilter and is only making partial contact with the safety switch. Especially if it's sitting on uneven soil or when the bucket get partially full the weight of the bucket is pulling it out of kilter because it's sitting on soil, rather than a hard floor. If nothing else, place it on a 1/2" piece of plywood or OSB and level it.
To be totally candid, I have some concerns about leaving a dehumidifier running, unattended in the crawl space of a house. There's to many things that could go wrong that would have disastrous results.
Comfort-aire model bhd501b unit comes on then goes off-bucket full light flashes- code comes ch-10
I've had to strap several buckets on with bungie cords; they shake some and the bucket full sensor thinks the bucket has been removed.
LCD READS CH 1 SHUTS DOWN BUCKET FULL LIGHT COMES ON
lcd reads ch 1 shuts down bucket full light blinks red
Top Maytag Dehumidifiers Experts
Frank Fernandez
Kirk Augustin
Kirk Augustin
Paul Carew
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
