I have read all about this camera that you have mentioned here but what is its price? so that we may easily buy it for our photography. https://www.theacademicpapers.co.uk/coursework-writing-service.php
How to fix lens errors just watch the video.
SOURCE: Error # E45
If the camera is under warranty i advice you give it for
service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following
the procedure below..
it may be the lens contacts or grit in the gears..
open it up on the side of the lens you will see a row of thin gold colored
contacts that report the lens position back to the cpu sometimes these get
dirty or bent.on the side of the lens is a motor, look where the gear meets the
lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant
happen unless its been dropped or bashed, in which case it may be broken.
Also i have heard some people bashing the camera a couple of times to get it
working..
hold the camera and bash the edge next to the lens against the palm of you hand
as hard as you can, This should work.
Goodluck,
Please don't forget to rate or accept the solution
SOURCE: says lens error!!!!!
The best solution is to take it to Best Buy and have them look at it. The Kodak camera could still be under warranty.
SOURCE: I dropped my camera and it won't turn on!
OoW repair: 48,44 pounds
Alternative Trade up: Where you trade your old camera to a new camera for 25-30% less than market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: Lens Error 22. Lens
Hello
The problem is that the lens has become stuck in the barrel
after dropping it. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
SOURCE: Camera error #E45
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
