Kodak Esp 5210 All-in-one Inkjet Printer Logo
A
Anonymous Posted on Oct 25, 2013
Error code 3601 - Kodak Esp 5210 All-in-one Inkjet Printer
Need RCA DVD player codes for my sentry really big universal remote... Please n thank you
  • RCA DVD Player 3160 , 3161 , 3302 , 3370 , 3371 , 3393 , 3409 , 3477 ,3505 , 3517 , 3601 , 3604
  • RCA TV 1000 , 1003 , 1004 , 1005 , 1006 , 1007 , 1019 , 1054 , 1055 , 1082 , 1096 , 1098 , 1099 , 1100 , 1101 , 1102 , 1103 , 1129 , 1179 ,1181 , 1188 , 1190 , 1196 , 1202 , 1203 , 1212 , 1215 , 1233 , 1257 , 1258 ,1266 , 1278 , 1279 , 1281 , 1286 , 1352
  • RCA VCR 2000 , 2003 , 2007 , 2013 , 2021 , 2022 , 2055 , 2056 ,2082 , 2083 , 2084 , 2085 , 2086 , 2087 , 2088 , 2089 , 2090 , 2091 , 2100 ,2107 , 2115 , 2120 , 2125 , 2140 , 2173 , 2184 , 2250 , 2252 , 2253 , 2261
TAKE APART A SHARK 3601
My shark 3601 died on me. A replacement is on its way but I still wanted to take a peek inside. After trying to get it open for about two hours, I figured it out. You have to remove the small screws by where the handle goes in. Then you can work your way inside. I removed all if the obvious screws to my frustration. I probably won't be able to put it back together again but I sure know how to take it apart. By the way, shark is sending me a replacement one for forty bucks.
Quiero intalalor en mi pc
Conecte el adaptador inalámbrico. Ponga en el cd con los drivers para el mando a distancia 360. instalar el software. a su vez en el controlador. debería funcionar. Bam.
1helpful
My printer is reprting the following errors and I don't know how to fix it. I keep trying to print a Word document but it doesn't give me anything until I print out a test page. Error Code 3501, 3601, and...
According to Kodak....
To resolve this error (3501 & 3601), close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Here is the link where I found the above solution:
http://support.en.kodak.ca/app/answers/detail/a_id/1467/kw/Error%20Code%203501/selected/true
I hope this helps.
Best of luck!!
Need new blades
if you need new blades u should go to a place.... i forgot what it was called but they can put new blades on them my huby had that problem as well
2helpful
Need Authorization Code for Photoshop CS2 serial number 1045-1082-3891-5153-9140-9615 activation number 5915 - 0697 - 9124 - 9914 - 3601 - 6546 - 8187 activation type: Normal send me e-mail at...
activation number 1319 - 5168 - 9535 - 4287 - 5433 - 4005 - 7259
send me e-mail at illari_ic@hotmail.com
I need change the battery, how can i buy other ?
you will find the battery you need at shaveroutlet.com
Unlock to nokia 6300
hi guys u can try 12345.its nokia default code.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
