I forgot my pin number i cannot use my phone need help.
There's no way to fix this, hence having a pin in the first place.
You need to use the PC companion suite to wipe the phone and install the system from scratch.
You can still access the memory card by removing it and using an sd card adapter allowing you to take off any data you need. (hopefully you do regular backups and the relevant file/s will be on your memory car, ie tel/numbers and contacts/emails etc, so when you restore your phone you can import everything back onto the clean system).
http://talk.sonymobile.com/t5/Xperia-pro-Xperia-neo-V-Xperia/Hard-Reset-Forget-Screen-PIN-CODE/td-p/242824
