Miele KFN 12823 SD1 Index 20K 164 evaporator sensor location
The error code you are experiencing on your Miele KFN 12823 SD1 with four beeps and flashing of the super freeze LED, along with the 9 and 5 LEDs on the fridge temperature block, is indicating a problem with the fridge evaporator sensor. This sensor is responsible for monitoring the temperature inside the fridge compartment and is located in the fridge section.
According to the service manual, the evaporator sensor for your model is located inside the fridge compartment, behind the light unit and it can be accessed by removing the light cover. The sensor is connected to the main control board via a cable.
It's important to note that the location of the sensor can vary depending on the specific model. In your case, since the sensor seems not to be behind the light unit, it could be that it is foamed-in.
If you want to replace the sensor, you will need to carefully remove the foam insulation in order to access the sensor. This can be a delicate process and it's important to be careful not to damage the insulation, which can affect the cooling efficiency of the fridge.
It's recommended to have a professional technician to help you with the replacement, as it might involve handling with refrigerant and electrical connections.
It's also important to make sure that you have the correct replacement sensor for your model and to follow the instructions in the service manual to ensure a proper installation.
