Broksonic TV Logo
Posted on May 06, 2009
Need a code
I have a living solution remote and i need the code
How do I program a living solutions remote to a vizio tv?
To program a Living Solutions remote to a Vizio TV, you can use the following steps:
  1. Turn on your Vizio TV manually or using the power button on the TV remote.
  2. Press and hold the "Code Search" button on the Living Solutions remote until the indicator light stays on constantly.
  3. Press the "TV" button on the remote to switch to TV mode.
  4. Enter the 4-digit code for Vizio TVs. You can find a list of Vizio TV codes in the instruction manual that came with your Living Solutions remote or you can search online for the correct code.
  5. Press the power button on the Living Solutions remote. If the TV turns off, the remote is programmed successfully. If not, repeat the steps with a different code until you find the correct one.
  6. Test the remote to ensure it is working properly. Try changing channels, adjusting the volume, and accessing the menu options on your Vizio TV.
If you are still having trouble programming your Living Solutions remote to your Vizio TV, you may want to check the batteries in the remote, ensure there is a clear line of sight between the remote and the TV, and try resetting the remote by removing the batteries and pressing all the buttons for a few seconds before reinserting the batteries.
Living solution code to program to a Vizio
RC: Living Solutions (or Innovage) jumbo universal ...
Remote Central https://www.remotecentral.com > rc-remote > thread
Jun 10, 2007 - Hold the device button you want to program for 3 seconds & release. Push & release the power button & the red light will remain lit. Push the ...
Living Solutions Jumbo remote need codes - RC
Jan 18, 2008
RC: Living Solutions Jumbo URC - Remote Central
Jun 20, 2011
More results from www.remotecentral.com
Remote Codes / Universal Remote
Vizio https://support.vizio.com > article > Remote-Codes-Un...
Remote Codes / Universal Remote ; 2 Digit TV Remote Codes 19 ; 3 Digit TV Remote Codes 502 627 004 113 505 011 ; 4 Digit TV Remote Codes 1758 0178 1756 0128 0117
Missing: Living ‎ solution
How to Program a Living Solutions Universal Remote
Techwalla https://www.techwalla.com > Tech Support > How To
Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc.
1helpful
2answers
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
9helpful
Living solutions jumbo remote codes for a sony tv.
The codes are ,002,006,071,128....hope this was helpful..
1helpful
2answers
I allready did. need number codes for my hitachi useing living so
Try the following codes:
From the Living Solutions 'Colossal' remote/Brookstone Jumbo Universal Remote (identical codes):
Hitachi TV...041, 042, 058, 059, 068, 073, 075, 078, 101, 117, 126, 127, 131, 134, 140, 145
I would think that the 'Colossal' would have the same codes as the 'Giant' version since they are from the same company. If they don't work for some reason, try the Innovage Jumbo Universal Remote codes in their manual (see below).
References (PDF Manuals):
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions
http://www.brookstone.com/jumbo-universal-remote.html
http://www.remotecodelist.com/remotes/#comp_14
P.S. I'm new to this site, but why was it asking me to recommend a remote??? I just inserted the only remote I could from the drop-down list that was relevant to this question.
I need a code list for my living solutions remote control and my tv is daewoo
MY MOTHER'S LEAFLET (doesn't state Living Solutions) GIVES THE FOLLOWING CODES FOR DAEWOO TVs: -
004,005,009,017,018,019,042,058,082,085,097,100,126,,127,130 and 138
Good Luck
24helpful
7answers
Living solutions remote control codes
I have a Universal Remote Control Model ATC-1311 Giant remote. I have lost the codes to and instuction book to. Can you tell me where to get at least the code for my T>V> Thank you
Top Broksonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
