Need wiring diagram and electrical hook up info.
SOURCE: electrical wiring diagrams
try http://www.etrailer.com/faq-wiring.aspx. This should help. Mike
SOURCE: I need a diagram that shows how to hook up the
80's Honda repair manual available at a discount parts store should be of great help as they refer to color code and term. number or letters.
SOURCE: i need a wiring diagram for a 2002 883 harley sportser
If you are going to install a new ignition unit, all you basically need to know is which wire is the "HOT" wire. Disconnect all the wires to the coil, turn the ignition switch on and use a test light to find the "power" wire. Once you know which wire this is, you'll need the wiring schematic for the particular type of ignition unit you're installing on your bike. Usually, if you got the website for the manufacturer, they'll have "installation instructions" under their "Technical" section. Usually, with a dual fire ignition system, there are only three wires to hook up. Good Luck!
SOURCE: I need an electric diagram for a echols popper
Try calling the manufacturer at: (573) 734-2210
SOURCE: need to weld alum ,have
You will never weld aluminum with CO2, you need straight pure argon. The best aluminum wire for starters is ER4043 and 030 diameter will work better with this machine. If wou don't have a spool gun it will be pretty dificult, but it can be done. First need to change the liner of your gun, instead of a steel one, it must have a teflon liner, and your tensor at drive rolls must be set pretty low (less pressure the better). A knurled type drive rolls will avoid the slipping of the wire.
Regarding the initial setting, you must crank up the wire speed to a higher speed then work it down as need it. Heat set it at low.
That's it!!
