Its the camera ic fault in the main board.the ic is not available except the service center.and service center has stopped providing this particular ic of the main board.you are not the only 1 facing this problem.there are thousands of users facing this same problem due to this stabilizer not available,as the ic is faulty it will never get stabilized.
some users gone for new camera and some are still waiting for the .
as in this mode also some functions of camera are working perfectly but only sliding the lens and taking a video is not possible .but many users are able to click the photos in this mode too.
thanks.
keep updated.thank you for using the fixya.
If this is a new camera return it. Some defective casio as well as other models have been having this problem. It is a defective model.
try resetting the camera if you can. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," or, removing the batteries for a few minutes. After which, you should have the camera reset to factory default settings.
Another tip for when you get home is to go to to the website and look for firmware updates. Download and install them.
Are you working with a Casio as this error is common with the Casio user.
In Casio EV-7, anti-shake only works in S-Mode or M-Mode and the speed must not be more than 4 seconds, which means the lighting must not be too dim.
If you have set it to the correct mode and lighting condition is not too dim, then you got to perform one more step - to set the anti-shake to on.
" In Record Mode, press Menu button
On Rec tab, select anti shake "
You will be given 3 options, Auto, Camera shake, Image blur.
Select Auto or Camera shake.
2. In connection with this, you may wish to read about the test on anti-shake function for the camera at DP Review
Thank You
SOURCE: Pictures
Call 800-706-2534 and option 2. That is casio repairs. They will know exactly what your talking about if you say you have a stabilizer error. :)
SOURCE: EX-V7 Casio Camera Stablizer Error
The problem is already fixed. I sent it to Casio Repair Office to get it fixed. They will repair for me without any charge and mail it back to me.
Thank you for the offer though.
Naweed Jan
I have removed the battery several times (once to have it checked for strength - it is full charged), The camera won't stay on long enough for me to get to the "menu" function to find "reset" function. When I have removed the battery and re-installed it, the setting comes up to set date and time, then goes right to Red Error Banner staing Camera Stablizer is not available.
No, this is not a new camera. Was working fine until a couple of weeks ago. This camera is 2 yrs old.
