Is there a universal remote conrol for a Bonaire DS125 evaporative air conditioner and if so what brand and where can I get it from?
If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved (remember that at times a bit of
to and fro dialogue may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: my universal remote needs a code to be programed
There are many codes for Zenith TV's. First, try this website:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Note if your remote uses 3-digit codes or 4-digit codes, and choose the appropriate code list.
