Washing Machines Logo
A
Anonymous Posted on Jan 04, 2014
Fault code 137 - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Engine Code: 128-545-137
128-coolant thermostat,137 bank 1 sensor 2 after catalytic conv.exhaust gas temp.sensor 545 bank 1 sensor 1.
Fault code 00 01 Ad
Fundamentals of Medium/Heavy Duty Commercial Vehicle Systems
https://books.google.com/books?isbn=1284041166
CDX Automotive,, ‎CDX - 2015 - ‎Transportation
If no fault codes are active, the warning lamps remain lit. ... (ABS) 128 - Engine 130 - Transmission 136 - Brakes (ABS) 137 - Trailer (ABS) FMI 00 01 02 03 04 ...
I have a 2003 grand am 4cyl i have three codes PO137,PO141, PO442 and since i parked it on the 17th and then never went anywhere till the morning of the 19th my car wont start it rolls but wont catch...
The 137 code is low input,rear o2 sensor,141 is a preheat fault at the same o2 sensor,the 442 is an evap leak (like a loose gas cap )
None of these codes would cause a no start condition.I think a fuel pressure test should be first,at least see if you hear the pump run for about 3 seconds as the key is turned on,don't have to crank it just turn the key on and listen (or a helper) at the fuel filler neck.
Check engine light came on after convertor was replaced. code po 137. Replaced both o2 sensors and still have the same code and check engine light
Well you would need to use a scanner to monitor the data coming from the sensor after the cat. Code 137 means the data voltage is too low or zero. The sensor generates ac voltage based on the amount of unburned oxygen in the exhaust.
The actual problem could be an exhaust leak closer to the engine, or that new cat may not be up to oem standards.
I have a 93' Ford Taurus that failed emissions
run the fault codes to find the faulty sensor
sensors that control the exhaust emissions are the HO2S ( heated oxygen sensors in the exhaust manifold/s
the O2 sensor ( oxygen sensors after the cat converters ) and the EGR unit that recycles exhaust gas back through the engine to re-burn the gasses
Engine computer reads code 133 and 137......need to know what it means. I have a 2002 daewoo laos
ok this one is simple code ( 133 ) is ( 02 sensor circuit slow response) ( bank 1 sensor 1) and code ( 137 ) is ( 02 sensor low voltage ) ( bank 1 sensor 2 )
Trouble codes 171, 174, 137 & 401 came on after engine replacemen
did they ever reflash the ecm with the new codes for the motor
Top Fisher and Paykel Washing Machines Experts
Frank Fernandez
gerbee gomez
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
