I've read several posts on the "red flashing error light" on the Brother HL-2170W. I have mine hooked to a mac - but I'm sure the pc is the same way. One other previous post said look for a paper jam. Well, there are only a few places to look...and I found no paper jam UNTIL I removed the toner cartridge and looked UNDER the cartridge and VOILA, there was a paper jammed underneath. I removed it and I'm back in business. Normally paper jams when it is almost out of the printer and you can locate it by opening the back of the printer. Well, this one was "sneaky" and hid completely underneath the toner cartridge.
Hope this helps someone else...
HI there it sound like you have either jammed the paper exit sensor up or broken the arm of it
youcan find the sensor by the rollers that the paper exits the printer through there should be a small platic arm haning down accross where the paper comes out to tell the printer that the paper has come out if it is jammed in the up position it will make the printer think there is still a peice of paper in the hot fuser unit and wont let the printer start up .
So carfully have a look at the fuser exit locat the arm and free it so it swings down freely and the problem should be solved when the printer is restarted
Regards Al "alstech"
If you found this info usfull or fixed your problem please leave feed back
Hi There the best way to try and remove any paper ( I presume Its In the fuser (hot Roller section) would be to unscrew the fuser which will allow it to run free then just pull out the problem is that you are trying to turn the whole copier when all the gears are meshed and henthe paper tears
Regards Al "Alstech"
A piece of paper is actually inside of the printer... I have tried pulling it out with tweezers and with my hands but it is ripping and won't move... FML
Is there anyway I can push this mother out or do I have to unscrew the whole fu***ing thing
