Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
A
Anonymous Posted on Jan 08, 2014
Error code a02 - Indesit 24 in. DE73 Evolution Free-standing Dishwasher
A02 error code WA456DRHDSU/AA This is the only code Im getting.
I could not find that code applied to a Samsung washer, only different mfgs. Contact with Samsung "Chat" states A02 is a communications error.
Recommend you check cable connections at the control board
Have you tried "smart care" app with this machine? Suggest try and see what it says is wrong.
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
How do I fix my a02 trouble code on my rheem ghe100-160a water heater
Commercial high efficiency gas
Rheem does not post service manuals or service bulletins for error a02, and installation manual does not show error codes
manual says to call for service
800-432-8373 in US
800-268-6966 Canada
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Error code a02 on my dishwasher ide 750
clean out water pump filter or replace w/pump
Downgrade bios A07 to A02 of dell N4030 for
Never a good idea to downgrade BIOS revision. Could cause you to have to replace the system board if it doesn't install properly.
2answers
What does A02-509 mean?
this is the code for a color, these values are the Hex values of a particular color within the RGB
go to http://www.color-hex.com/color/a02509 if your would like further explaniation
12helpful
3answers
Error code T01-521 on RISO RN 2130
I have an RP3105 with this error code. Next to the magnetic clamp that holds the master in place is another lever mechanism that lifts the master to present it to the waste master mechanism. This has a small white plastic wheel which is engaged to make it move. On my machine the wheel had broken in half. I superglued the two pieces together and everything works perfectly
1helpful
Need driver for my dell motherboard a02
what *********** board type???
try this link www.user-guides.co.uk/.../motherboard/motherboardmodel/motherboard-model-rev-a02.html
3answers
Paper Jam error
Try feeding paper from the front, if it works, your paper pickup rollers maybe having problems (dusty/worn-out).
- Bianca
Top Indesit Dishwashers Experts
Paul Bade
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
