A
Anonymous Posted on Jan 10, 2014
Lexmark printer manuals
X642e
2 Related Answers
Anonymous
  • Posted on Sep 11, 2009
SOURCE: Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Anonymous
  • 126 Answers
  • Posted on Nov 23, 2009
SOURCE: how to install Lexmark X642e printer
Read the manual and follow the instruction provided by your Printer Lexmark.
Just read it.
1helpful
Lexmark x642e error message 954.95
Seems you have a bad interface card.Try replacing it.
I WORKING ON A LEXMARK X642E WHICH CAN NOT SEND OR RECIEVE FAXES. WHEN TRY TO GO INTO FAX SETUP MENU IT SAY MODEM FIALED TO INITIALIZE!!
It possible that this is a bad modem, try turning off printer and unplug fax. If you are getting same error message, you need to get a replacement of the modem card.
For further assistance please contact Lexmark Technical Support.
I installed a maintenance kit (fuser, charge roller, transfer roller & pickup rollers) in my Lexmark x642e and I'm still getting light horizontal lines approx. every inch or so thru the page
Have you tried a different cartridge? Was there much spilled toner inside the printer? If you go into menus, and then help menu you can print a print defect guide that you can line up on your print and it will tell you exactly which part is causing the issue.
How to delete unwanted Shortcut numbers form Lexmark x642e?
If the printer is connected to a network, type the IP address of your printer on the address bar of your web browser. On the printers web interface, click on Configuration and select Security. Click on Function access and select a specific function of the printer, click the drop down button and select function disabled and the click submit.
You may also use the printer operator panel. Click on Menu button >Settings > General Settings> Home Screen customization > select the specific function and select do not display and click on submit.
For further assistance, please contact Lexmark Technical Support.
Hello, I got an Lexmark X642e with 900.80 error (when the ADF scanner is connected). When scanner is not connected, the printer is accessible via network and can print w/o any problem. Firmware is...
A 900.80 error indicates a problem with the current print job or with a part within the scanner unit of the printer. Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/qxvmNN
For further assistance, please call Lexmark Technical Support.
1helpful
HOW TO RESET LEXMARK X642E FUSER KIT COUNTER
Hit the menu button or the Key Button
Go into the configuration menu
Touch the arrow that says "Reset Maintenance Counter"
Select the Yes button. as you can not manually change the page count number.
It will reset the counter for you.
1helpful
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
How to install Lexmark X642e printer
Just read it.
Lexmak x642e
Have you powercycled the printer? Is the printer showing ready, currently?
1helpful
Cant find counter on my lexmark x642e can any one help, I have no manules .thanks
Maintenence counter is in Configuration Mode.
Power on the printer while holding down the 2 & 6 buttons. Continue holding buttons for 20 seconds. You will find the counter in Maintenence counter and can reset it there.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
jdthefixer
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
