Hi, We have a Ricoh 1515F device, and I try to set the network interface, but no [Interface settings] option in the [system settings] menu. What can I do to set the IP address? Best regards
SOURCE: Can't Network Print
in printer you should log in as administrator and there should be network settings, where you can put in ip address and gatway and so on.
SOURCE: I would like to know how to reset the Lexmark
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
SOURCE: Gestetner DSM616 no network config
Sounds like you don't have a print or print/scan option in stalled. All machines come with network port but only works if option is intalled. You can check if you have the option installed, maybe just not activated. At the back just abouve the network port there is a cover that covers 2 sd card slots. If the is no sd card installed you will not be able to print to the machine. If the is a sd card installed contact me again and i will help with activation
SOURCE: I'm having a problem reconfiguring
go to Wireless Printing Center
If you need more help come back.Post / thumbs / testimonial are welcome!
