1994 Mercury Tracer Logo
Posted on May 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help my 94 automatic 4 cyclinder is leakin oil I'm finding under the car could or sould I replace the oil pan and how
  • Anonymous May 11, 2010
    The first thing you need to do is "find your leak". Gravity makes oil fall under the car.
Frank Fernandez
Level 3:
President:
  • Master 791 Answers
  • Posted on May 31, 2009
Frank  Fernandez
Master
Level 3:
President:
Answers
791
Questions
0
Helped
296549
Points
2249
I would first clean the engine to determine exactly where the oil leak is originating. It could be the oil pan gasket, valve cover gasket, sending unit, etc...
Gunk makes a decent degreaser (just follow the directions on the can). Once the mess is cleaned up it will be easy to find exactly what is leaking and continue from that point to replace the leaking gasket/component.
If it turns out to be the oil pan, you will see the bolts that secure the oil pan to the block from underneath the vehicle. When replacing the pan with the new gasket it's important that you torque the bolts in a cross torque pattern so the gasket has a chance to seal on all sides.
Anonymous
Level 2:
Sergeant:
  • Expert 179 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
179
Questions
0
Helped
75153
Points
590
Not oil pan but gasket remove oil pan scrape off all old gasket and put on new one the best thin to do is glue it on the oil pan first and let dry with bolt holes in line the glue it to block but this might no be the problem headgasket could leak oil pump gasket valve cover gasket
Top Mercury Experts
Kirk Augustin
Kirk Augustin
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
