Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
Kathy Chance Posted on Jun 02, 2009
Pullstring wont pull out
I have apoulan/weedeater xt200/xt25 featherlite and the pullcord wont pull out .its like its locked up
  • Anonymous May 11, 2010
    Did you mix oil with the gasoline?
1 Related Answer
Greg Smith
  • 35 Answers
  • Posted on Apr 09, 2009
SOURCE: Featherlite will not start
first never let any one browe your tools or your wife thay could break eather of them noe get a small screwdriver find the air adjutment screw on carb turn it in count the turns till it stops then pull it out by turning it counter clock wise dont louse any spring that might be there its out get carburator chock cleaner use the little tube put it in hole were the screw lived at and let it have a good blast or 2take out spark plug and pullthr start rope 10 or 15 times put plug back put air screw back 1 3/4 out from bouttom i think if you had dif number try it first if that dont fix it you may need to take carburator off take it apart and clean there is two gas lines that go to tank if one of the lines has a filter on it inside the tank if thay get water in there threeeere pluged up might get new one there fun to get out of tank or take to shop if you dont have all the tools or homedepo and buy good luck
Top Poulan Garden Experts
john h
Kirk Augustin
Kirk Augustin
wadingriver
wadingriver
Are you a Poulan Garden Expert? Answer questions, earn points and help others
