Start up and stop afther 2-3 seconds
SOURCE: washing machine error code h6
hi,
seems a spade connector had dislodged itself from the back of the machine reattached and all works seems it was a heat problem.
Hope this helps
please give me a FixYa rating if the solution works.
Thanks
SOURCE: engine light on car start but stop afther 1 or 2
Your description appears to be a normal condition. When you turn your ignition to on, the "check engine" light should turn for 2 seconds then turn off and stay off, this is the self-diagnostic mode. If it turns off and then turns on again, you have a diagnostic trouble code(DTC). Go to your local autoparts store have them pull the code for free. Each DTC has a corresponding problem.
SOURCE: error code h6
H6 on a daewoo is a heating element problem. Run it on cold to double check! There are generic youtube videos to show u where to locate the heating element. Check the wiring as this can work loose.
Hi Humphrey Sambo, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Ok sir, l will!!thanks a lot
Hi sir, as I state before about the error code h6 of A/C Comfort Star CCH018F, I replaced the pipe sensor afther measure the old one. The charge of freon is ok, the thermistor is good, blowermotor and everything is working fine during start up. The unit runs for about 5-8 seconds, stops completly and shows h6 error on display board. I hope this information washelpful to you. Thanks a lot for your time. regards. Humphrey!! g C
